Hy TK, for your response,
the resolution of the scale is 0.005mm and the system is 5mm pich
ball screw/3200 u steps per turn, so is 640steps per mm and in inch is 16256 per
inch.
The motor drives I use is a kinko 2M880N, with a Nema 34 ,8Nm stepper
motor. for X and Y. In Z I use a Leadshine Em806
I try to use the software you mention , but is not clear in the
documentation on how to do it? or I don´t know how to do it.
Imagine, I move X + 10mm (0.39 inch ),then I make a “0” in the
Kmotion DRO, and then I move X +300mm(11.81 inch), then I move X – 300mm (11.81
inch) in the kmotion will appear 0, but like I have a digital scale and I
have an external DRO I measure , for example 299.8mm, I will have a backslash of
0.2mm ,
How do I make the adjustment in the backslash?
If I make Close Loop. I suppose all this errors like backslash will
be corrected by the software. Or not?
Regards Santiago
